gprasada
Jun 20, 2021Follower
How do i connect my existing NBN phone to the Orbi router
Hi I have an Orbi mesh system installed and the NBN modem plugs directly into the Orbi router, need some advise on how to plug my existing VOIP phone into the router so I can use it.
Jun 23, 2021Guru - Experienced User
Contact the mfr of the VOIP phone for setup and support information.
gprasada wrote:Hi I have an Orbi mesh system installed and the NBN modem plugs directly into the Orbi router, need some advise on how to plug my existing VOIP phone into the router so I can use it.
