peteb68's avatar
peteb68
Initiate
Dec 11, 2021
How do I connect my RBR20 to a Verizon LTE Gateway?
I am trying to use my NetGear Orbi RBR20 with my Verizon LTE Gateway. Every time I plug it in, the Verizon LTE Gateway status goes RED. How do I configure this so it will work?
  • plemans's avatar
    Dec 11, 2021
    what verizon gateway is it?
    most of them have their own integrated router and it causes a double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
