Bagpiperob
Sep 26, 2020Aspirant
How do I connect RBK13 and whole Home hub 3000??
I have Bell Canada Whole Home 3000, and I'm trying to connect the ORBI RBK13-100CNS. Can anyone help with this?
CrimpOn
Sep 26, 2020Guru - Experienced User
I searched (and searched) the Bell Canada Home Hub 3000 web information and never found a picture of the back side of the box, where there should be an ethernet port that the Orbi would connect to. Can you provide a picture of the back side?
Bagpiperob
ports are on the side on mine.
- FURRYe38Sep 27, 2020Guru - Experienced User
If the ISP modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Bagpiperob wrote:ports are on the side on mine.
