savaasio
Jul 04, 2023Aspirant
How do I enable bridge mode after setting up an Orbi RBR50v2
I have setup my Orbi with an old Verizon DSL router/modem After I setup the Orbi, I was no longer able to access the administrator page of my old router/modem, and I had forgot to enable bridge mode...
michaelkenward
Jul 05, 2023Guru - Experienced User
After I setup the Orbi, I was no longer able to access the administrator page of my old router/modem, and I had forgot to enable bridge mode and disable wifi on the old router/modem.
- Disconnect Orbi from modem/router.
- Reset modem/router.
- Go into modem/router controls
- Put it into modem/only mode
- Set up Internet connection
Then go through the usual network set up process
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
My experience with modems is that it isn't easy to get at their controls when they are in front of a router. Fortunately it is something that you do rarely, if ever.
