sbergy4
May 18, 2020Aspirant
How do I enable multicast
I am using the Orbi RBR20 with a Uverse gateway. The Orbi is set up as an AP and the gateway's wifi was disabled as the instructions suggested. I have a Sonos soundbar and Sonos One with Alexa built ...
sbergy4
So if I'm understanding you correctly, I should re enable my Uverse Gateway's WiFi for both the 2.4 and 5 ghz radio status? In some video I watched on setting up the Orbi, it instructed me to disable these on the Uverse gateway.
May 18, 2020Guru - Experienced User
No. multicast is a different feature on the host router. Nothing to do with wifi.
