dkalck
Aug 13, 2018Aspirant
How do I enable Teredo for by Orbi Router?
My son can no longer hard to his xbox for gaming. How do I enable teredo tunneling with Orbi?
Aug 13, 2018Guru - Experienced User
Might reset his xbox. Press the power button until it turns off. Connect a LAN cable between the router and xbox. Power ON and check to see if it gets an IP address. Make sure the xbox is not setup for a static IP address, use Auto IP addressing.
Check mark IPv6 to enable it on the orbi router if your ISP supports IPv6 natively.
Set up a IP address reservation for the xbox as well.
