awasen
Jul 20, 2020Follower
How do I figure out why port-forwarding is not working?
I have an Orbi setup and a RaspberryPi running Node-red in my network. The Node-red server is listening on port 1880 using HTTPS. Accessing the Node-red app works fine in the LAN, e.g. https://192....
schumaku
Jul 23, 2020Guru - Experienced User
Try a different port than 443/TCP .... well (un-)known feature of Netgear's newer (?) router implementation: 443/TCP won't be freed up even if no other services like remote access and the like are changed to other ports. Don't wonder a second if this feature has made it to Orbi, too.
