IcedCorn
Jun 30, 2019Tutor
How do I find Cable Modem IP address if using Orbi
I have an Orbi, I'm using as a Router with a Hitron cable modem that's also a router. I have the Hitron in IP Passthrough mode to the Orbi. However, I can't figure out a way to login to the Hitro...
IcedCorn
Jun 30, 2019Tutor
I think that will just direct me to the Orbi.
CrimpOn
Jul 01, 2019Guru - Experienced User
Well, with the Hiltron in passthrough mode, the WAN port on the Orbi will have the public IP address from the ISP (Sprectum, Cox, whomever). The Orbi typically assigns itself 192.168.1.1 as the internet gateway for all attached devices and uses DHCP to assign addresses in the 192.168.1.x range to everything attached to itself. So, 192.168.0.x is not part of the Orbi network. Neither is 192.168.100.x
Back when I had the UBEE operating in router mode, I was able to connect to it, and my (dim) memory was that the UBEE web interface was at 192.168.100.1 or 192.168.0.1. I can't do that anymore because my UBEE was replaced with a "simple modem" and I have (as yet) never found a method for the user to connect to a management interface on the modem. (I want to look at "signal levels".)
