IcedCorn
Jun 30, 2019Tutor
How do I find Cable Modem IP address if using Orbi
I have an Orbi, I'm using as a Router with a Hitron cable modem that's also a router. I have the Hitron in IP Passthrough mode to the Orbi. However, I can't figure out a way to login to the Hitro...
IcedCorn
Jun 30, 2019Tutor
Because I may want to turn on WiFi on the hitron, because the speeds seem better sometimes. I don't understand why but they do.
Same with wired to hitron vs wired to Orbi. And the Orbi is literally right next to the hitron.
michaelkenward
Jul 01, 2019Guru - Experienced User
One way to achieve this is to put the Orbi into AP mode.
A lot of people do that and seem to lose little in the way of useful features.
- CrimpOnJul 01, 2019Guru - Experienced User
If the Hitron is in passthrough mode and the Orbi is put in AP mode, then the customer has no DHCP server.
- michaelkenwardJul 01, 2019Guru - Experienced User
So, put the Hitron into modem/router mode and the Orbi into AP mode.
I didn't think I needed to explain that, but clearly I was wrong.
Sorry for the confusion. The conversation started becauses the user was not able to connect to the Hitron, and thus had no way to control it. I must have misunderstood.
