IcedCorn
Jun 30, 2019Tutor
How do I find Cable Modem IP address if using Orbi
I have an Orbi, I'm using as a Router with a Hitron cable modem that's also a router. I have the Hitron in IP Passthrough mode to the Orbi. However, I can't figure out a way to login to the Hitro...
CrimpOn
Jul 01, 2019Guru - Experienced User
Sorry for the confusion. The conversation started becauses the user was not able to connect to the Hitron, and thus had no way to control it. I must have misunderstood.
michaelkenward
The thing is confusing from the start.
That is because they had the thing in modem only mode.
There can be ways to access a device in that mode. I have a DM200 in modem mode and can in by detaching it from the local network and connecting directly from a PC. I don't know that that would work with the Hitron, but your suggestion of using a different LAN port might help if the user can work out what IP address the Hitron is on.
But that issue goes away when put back into modem/router mode.
