mcbainpc's avatar
mcbainpc
How do I flush the DNS cache on my Orbi system?
Hello, I am running an RBR50 with FW V2.5.1.8 and I've added a pi-hole machine to my network. Now I'd like to flush the DNS cache of the Orbi system so it must fetch all entries from the pi-hole box.
How can I flush the DNS cache of my router?  Thanks!
  • As FURRYe38 mentioned, the most obvious step is to reboot the router.  Orbi is built on the OpenWRT project.  I found this answer about flushing the DNS cache on it: https://unix.stackexchange.com/questions/8160/how-to-clear-dns-cache-on-dd-wrt
    In addition, DNS cache entries "time out".  This is an internet requirement in case some resource changes IP addresses.  So, no matter where Orbi got a DNS entry, it will eventually time out and the next time a device ask, it will come from the Pi-hole.
  • CrimpOn's avatar
    CrimpOn
