tmarcus1076
Oct 14, 2022Follower
How do I get a RMA
I have a Orbi AC1200 mesh router that no longer works. I can't get an RMA because it says I don't have support. The router is still under warranty. Tony
schumaku
Oct 16, 2022Guru - Experienced User
Head to https://my.netgear.com/ where you see all your registered Netgear devices.
Pick the device in question, for example ....
Find your warranty and support entitlements (very different remaining days!), and follow the [Request Hardware Support]. Provide some brief information about the issue, attach some graphics or files if available. Can't be easier and customer friendly.
