Mchain
Apr 04, 2020Aspirant
How do I get devices to connect to satellites?
I have a couple of satelllites. It appears they are both 5Ghz. all the devices downstairs still seem to connect to the satellite upstairs. see the video. Probably something easy to fix? Apprecia...
Retired_Member
Apr 04, 2020not clear on what your pic is suppose to show....it looks fine to me
there is lots of discussion about this topic in here you may want to do a search
even if you are able to do what you think you want to do, what do you think the gain is?
- MchainApr 04, 2020Aspirant
the sateliites are online as pic shows. I want the devices nearest the satellite to connect. So there is a computer and TV that are not connected to the satellite closest to it but rather go 2 floors up and connect there.
- Retired_MemberApr 04, 2020
Mchain wrote:the sateliites are online as pic shows. I want the devices nearest the satellite to connect. So there is a computer and TV that are not connected to the satellite closest to it but rather go 2 floors up and connect there.
ok...do a search....will all of this make things 'faster'?'
