Mchain
Apr 04, 2020Aspirant
How do I get devices to connect to satellites?
I have a couple of satelllites. It appears they are both 5Ghz. all the devices downstairs still seem to connect to the satellite upstairs. see the video. Probably something easy to fix? Apprecia...
Apr 20, 2020Guru - Experienced User
Mchain wrote:I have a couple of satelllites. It appears they are both 5Ghz. all the devices downstairs still seem to connect to the satellite upstairs. see the video. Probably something easy to fix? Appreciate any advice.
