rc_gamer's avatar
rc_gamer
How do I get the Satellite to switch to the wired connection?
Hello,   I am running: RBR50 Base Station (with Firmware V2.5.1.16) Set as an Access Point (AP Mode) 1 Satellite 1 NETGEAR Unmanaged Switch 1 Firewall (and ISP Modem) I initially setup my...
  • CrimpOn's avatar
    Sep 09, 2020
    There should be no need to "resync" or "reset" either the router or the satellite.  Nor is it necessary to disable Daisy Chain.  Having only one satellite, Daisy Chain is unnecessary and can be disabled, but it does not have to be disabled for ethernet backhaul to work.
    It is either (a) the cable or (b) the switch.
    How about this:  Temporarily move the satellite to the same room as the router.  Allow them to sync over WiFi (blue light).  Then, connect the satellite directly to a router LAN port using an ethernet patch cable.  The change over is not instant.  (5 minutes?)
    After verifying that the satellite will switch to ethernet backhaul, add the switch.  (router->patch cable->switch->patch cable->satellite).
    If this fails, "it's the switch".  If this works, "uh, oh. the cable."
