MSL-USA
Jul 30, 2023Aspirant
How do I isolate a 2.4 from 5.0 on the RBR50v2
Arlo sensor hub will not connect to the network (requires 2.4 g). I created a guest login but it still will not separate/restrict the login to 2.4. Help 🙂
michaelkenward
Jul 30, 2023Guru - Experienced User
MSL-USA wrote:
Arlo sensor hub ...
What's that? My Arlo hubs all have to be wired to the router.
The setup app uses wifi to talk to the hub. It should be possible to tell the wifi client to use 2.4 GHz, although my recollection is that it can still see the hub when connected to 5 GHz wifi.
You might like to check the section for your device for other conversations on this topic. There have been plenty of them.
Orbi Mesh Systems - NETGEAR Communities
