MSL-USA
Jul 30, 2023Aspirant
How do I isolate a 2.4 from 5.0 on the RBR50v2
Arlo sensor hub will not connect to the network (requires 2.4 g). I created a guest login but it still will not separate/restrict the login to 2.4. Help 🙂
Jul 31, 2023Guru - Experienced User
Separation of SSIDs is not supported or possible on Orbi systems.
Try this. Turn OFF the RBS. Then the power output of the 5Ghz radio to 25%. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
