wolfereeno's avatar
wolfereeno
Apprentice
Jul 16, 2019
HOW DO I KNOW IF I NEED ANOTHER ORBI EXTENDER?
I have a fairly new Orbi RbR50 + Satelite in a duplex apt with the satelite upstairs.
When upstairs, the wifi signals on my devices seem strong based on the devices indicator, but performance can be slow in some areas.  I've tried moving the extender around with no major change.  It seems to have a good connection to the base.  The performance seems to be bad mainly in a location where both the extender and base might have equal signal - so perhaps there's some fighting over the connection?   How do you diagnose or optimise such a thing?
I've toyed with adding a second router upstairs, with one at each end of the space, but before I do that I want to make sure I have the current setup figured out.
I installed the latest firmware today but haven't done much testing yet.
Thx
  • FURRYe38's avatar
    Has a full power cycle of the system been performed after the FW update?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • wolfereeno's avatar
      wolfereeno
      Apprentice
      Latest Orbi firmware 2.3.5.30.  Didn't do a power recycle.  I let the Orbi do its regular reset.  I'll try powering it off/on later.
      Aris TG1672G modem
      The home is about 1500 sq feet.  There's also some outdoor space.   The routers are now about 50' feet apart.  If I move it closer to the base, I'll loose a lot of signal to the outdoor deck.  If I got another extender, it would be to handle that scenario.
      There are TONS of wifi signals all around me.  I live in a big city.   I count 30 right now.
      Channels for 2.4 is set to Auto, 5G set to 48.  Is it faster to set a specific channel?
      beamforming is on but not mimo or fast roaming.  WMM is on.
      Daisy Chain topology is on
      Preamble mode is automatic.
      Thanks!!
      • FURRYe38's avatar
        wolfereeno wrote:
        Latest Orbi firmware 2.3.5.30.  Didn't do a power recycle.  I let the Orbi do its regular reset.  I'll try powering it off/on later. Please try this.
        Aris TG1672G modem
        This is a gatway modem which also has built in router and WiFi.This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Distance is good if your getting good signal and operation there.
        There are TONS of wifi signals all around me.  I live in a big city.   I count 30 right now. This could be a factor in good wifi operations.
        Being that your in a high populated wifi neighborhood, yes. You may need to lower the power output of the wifi radios from 100% to say 75 or 50% as a troubleshooting step.
        Daisy Chain topology is on. Disdable Daisy Chain when using just 1 satellite.
