wolfereeno
Jul 16, 2019Apprentice
HOW DO I KNOW IF I NEED ANOTHER ORBI EXTENDER?
I have a fairly new Orbi RbR50 + Satelite in a duplex apt with the satelite upstairs. When upstairs, the wifi signals on my devices seem strong based on the devices indicator, but performance ...
wolfereeno
Thanks!
I was able to turn the Arris into bridge mode. Wasn't that hard. I just had to temporarily turn on and connect to it's wifi and then login. So I did that and turned on Router mode on the Orbi.
Used wirelessNetView to see that the channel I'm using is pretty clear.
We'll see if things are better, but so far I can really only go by observation. Are there any utils I can run on a pc, mac, or phone to get a metric about performance and signal strength?
Jul 17, 2019Guru - Experienced User
Glad you got the modem bridged. Now you can enjoy all the Orbi features.
I use wifi sweetspots on my iphone and WiFi Analyzer on my Android pad. There are several analyzers available for Pads, if you have one.
wolfereeno wrote:Thanks!
