Nothenemy
Feb 23, 2019Follower
How do I locate browser history in the ORBI menu? I'd like to block certain URLs.
How can I block a URL or two in the Orbi menu? I have been looking for a history window and haven't found one. Home network. Windows 7. Orbi has latest version of firmware.
michaelkenward
Feb 24, 2019Guru - Experienced User
What "history" are you looking for?
Your Orbi does not remember sites that you visited. That is down to the browser.
- ekhalilFeb 24, 2019Master
Otherwise you can also use Circle to see history of visited sited by all devices per user:
- michaelkenwardFeb 24, 2019Guru - Experienced User
That's not Orbi.
Circle?
Yes Circle is an ”extension” to Orbi :)
https://community.netgear.com/t5/Home-Networking-Stories/Circle-with-Disney-Parental-Controls-On-Orbi-WiFi-Systems-Now/td-p/1426264
