TJ2017's avatar
TJ2017
Follower
Feb 16, 2018
How do I Open Ports on Orbi?
Hi Folks, I'm reaching out to the community to see if there is a way to open ports on the Orbi router?  I received the Orbi AC3000 system (router & sattelite) for Christmas. This thing is a truly aw...
  • Roamabout's avatar
    Feb 16, 2018
    Chapter 8 of the user guide describes the Orbi port forwarding configuration. It is under the Advanced... Advanced Setup.. Port Forwarding/Port Triggering... menu of the Orbi web interface.
    You need to be using the Orbi as a router for this option, it doesnt apply to an Orbi in AP mode.
