emel1721
Mar 28, 2019Follower
How do I open Ports UDP500 UDP1500 and UDP123
I just got a cellspot from T-Mobile and it is telling me to make sure that these ports are open and I do not have any idea how to find them and open them. I would love some help on this.
Thank you!...
ekhalil
Mar 29, 2019Master
FURRYe38 wrote:
If this device is connected to the Orbi, and you have a modem only infront of the Orbi router, you can use the DMZ for this device On the Orbi.
Setup a IP address reservation for this device ON the base router and input this IP address into the DMZ ON the Orbi.
DMZ is a non-protected destination, so by doing as you suggested all attacks on Orbi will be directed to this device!
emel1721 Please forward only the ports that you need using the Port Forwarding menu (after resering an address to the device) as follows:
Mar 29, 2019Guru - Experienced User
Plausable however can be used. Something I have used for Voice devices which works for most cases. Haven't seen any attacks on my microcell in the DMZ.
