blasmazzeo
May 09, 2020Tutor
How do I Reset Orbi as Access Point
The root issue is that I have not been able to connect to my wireless printer from my windows 10 desktop for a several weeks. My destop is having connection issues with the devices attached to the O...
- May 10, 2020
I reset the Orbi to be an access point. I temporarily lost access to the printer and music server but restarting the Orbi and the PC fixed that.
(It looked like the Orbi automatically restarted when the change was made, but apparently that was not the case.)
We will see if the issue with internet access re-occurs again. Maybe this has solved the problem. Thanks for all your advice. (This is better than waiting days for a response from Netgear.) I will let you know tomorrow if this solution worked.
blasmazzeo
May 09, 2020Tutor
I tried rewiring the ethernet cables as you suggested and that did the trick. I plugged the desktop into the Orbi and left the Orbi connected into the wired router and was then able to access both the Orbi wireless devices and the internet with the desktop.
For some reason, the devices connected to the back of the ATT router can acess the internet but not each other. There must be either a firewall preventing that or a network needs to be setup in windows. Good luck trying to get that information from AT&T. If the automated answering system does not hang up on you (it uses covid-19 as the excuse) you end up speaking to a tech after waiting an hour that does not know what to do because it's not in his script. It was an ATT tech that had me move my ethernet connections from an ethernet switch to the back of the router after which I lost the ethernet connection to the Orbi.
It reminds me of the running joke on John Oliver where people in developing countries feel sorry for us because we have ATT.
If any one knows who to get the ethernet devices plugged into the router to talk to each other, it would be helpful.
May 09, 2020Guru - Experienced User
If you get it setup and wired properly:
ATT modem\router-----orbi (ap mode)---Devices
Devices
then reboot the (not reset) the whole network and devices. This will ensure they're all on the same subnet.
Also, make sure all your windows devices are setup on a "private" connection and not set to "public"
that should allow them to "see" each other.
- blasmazzeoMay 09, 2020Tutor
That solution would make sense except my Orbi has only 2 ethernet ports. Would need 4 to hookup all my wired devices.
- plemansMay 09, 2020Guru - Experienced User
A cheap gigabit unmanaged switch isn't a bad idea.
But if the orbi is in AP mode, it shouldn't matter if your devices are connected to the ATT device or the orbi, they should be on the same subnet. Again, do a system wide power off and back on so they pull new IP addresses.
PS. you put cbr40 in this post signature. The others had the RBR20. Which is it?
- blasmazzeoMay 10, 2020Tutor
I'm back to the configuration before my internet issues began. The Orbi is connected to the ATT router. My windows 10 desktop and my Vortexbox (Linux computer) music server are connected to a Netgear GS105 ethernet switch which is connected to the second ethernet port on the Orbi.
This has fixed the PC's ability to see the Brother Wireless Printer and the Bluesound music server (connected wireless to the Orbi) in my A/V setup can now see the music files on the PC and the Vortexbox.
But I now have the internet issue again that caused me to swap out the ATT router. The browser (chrome) on the PC has trouble resolving websites (i.e. yahoo, google, etc) when it is first used in the morning. Rebooting the PC fixes this. But I did not have this issue a month ago nor was it a problem when the desktop was connected directly to the router or to the Orbi yesterday.
There is something in having the ethernet switch in the connection that is making it harder for the PC to connect to the internet such as an address that is changed over night.
I have not changed the Orbi to the AP mode. Would this make a difference? When I initially set the Orbi up a year ago Netgear Support told me this that this was not required and there were no issues until a month ago. Also, is there another ethernet switch that would be more transparent?
P.S. It's an RBR20. The cbr40 was a typo.
