sunil_munsif
Feb 21, 2021Follower
How do I select my RBS50 Satellite on my computer?
Hi: any suggestions regarding how I can select the Satellite on my computer? When I check the app - I see that my computer is connected to RBR50 downstairs and not to RBS50 which is less than 15 feet...
Feb 21, 2021Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
sunil_munsif wrote:Hi: any suggestions regarding how I can select the Satellite on my computer? When I check the app - I see that my computer is connected to RBR50 downstairs and not to RBS50 which is less than 15 feet away. Any practical tips? Thanks!
