cliff1127
May 08, 2021Follower
How do I setup RBS50 to get internet via ethernet backhaul, and NOT extending the wireless signal?
Hi all, thanks in advance for your help. I currently have an RBR50 and and an RBS50... I have ethernet backhaul / ports setup throughout my home. How do I ensure the RBS50 is getting internet via...
CrimpOn
May 08, 2021Guru - Experienced User
cliff1127 wrote:Hi all, thanks in advance for your help. I currently have an RBR50 and and an RBS50... I have ethernet backhaul / ports setup throughout my home.
How do I ensure the RBS50 is getting internet via the ethernet backhaul? And not simply extending the router signal?
In the Orbinlogin.net portal, I see the Satellite listed in Attached Devices. It says connection type 5G and Backhaul Status as "Good"
When the Attached Devices screen says the backhaul is "5G Good", then it most certainly is NOT ethernet backhaul. I suspect something is wrong with the ethernet cable. (either the cable itself, or one of the RJ45 jacks is not terminated correctly).
Suggest you temporarily move the satellite to the same room as the router and connect it with an ethernet patch cable. After a few minuter (5-10), the Attached Devices should show the backhaul as Wired. This will establish that that the satellite is capable of ethernet backhaul.
Troubleshooting what is wrong with the ethernet cable is more difficult.
