bdrfam
Aug 19, 2021Aspirant
How do set up Ethernet connection with PlayStation?
I have the router connected to the Ethernet port in the wall. I have a satellite in my room. I want to connect an Ethernet cable from my satellite to my PlayStation, but when I do so, it acts as if I ...
CrimpOn
Aug 19, 2021Guru - Experienced User
"into the wall" does not provide enough information. What would be helpful is....
- Inforamation about those ethernet cables inside the wall.
Where do they go? (a central place in the house?) - Where is the Orbi router in relation to that cabling?
- Is there a patch panel or ethernet switch installed?
- When the PS was connected to the satellite, was that directly to the satellite with an ethernet cable?
