WillyQ711
Feb 24, 2021Aspirant
How do the Orbi devices recognize an Ethernet Backhaul setup?
Greetings, So I wanted to know how the Orbi devices, specifically my current setup with the RBS40 router and RBR20 Satellite, sense that I want or have an ethernet setup as a mesh ethernet backhaul ...
Feb 24, 2021Guru - Experienced User
All of mine have automatically set it up. And I've bebuilt my orbi setup several times. I used the RBK43 and RBK53 setups with both just auto-recognizing it. It required no input on my part
WillyQ711
Well that sounds easy enough.... How can you verify within the UI of the device that the satellite is indeed using the ethernet port for connectivity to the primary router rather than the WiFi connectivity?
- CrimpOnFeb 24, 2021Guru - Experienced User
WillyQ711 wrote:Well that sounds easy enough.... How can you verify within the UI of the device that the satellite is indeed using the ethernet port for connectivity to the primary router rather than the WiFi connectivity?
The Orbi web interface, Attached Devices page will show the backhaul as "5G" or as "wired".
- WillyQ711Feb 24, 2021Aspirant
Yes, That's where I was going and no devices would show after 3 logins. I rebooted both the RBR and RBS, and now all my devices are showing. Must have had a cached page stuck or something.
