WillyQ711
Feb 24, 2021Aspirant
How do the Orbi devices recognize an Ethernet Backhaul setup?
Greetings, So I wanted to know how the Orbi devices, specifically my current setup with the RBS40 router and RBR20 Satellite, sense that I want or have an ethernet setup as a mesh ethernet backhaul ...
Feb 24, 2021Guru - Experienced User
I recommend setting up the RBS vvia wireless first to ensure there connected to the RBR, then, connect them one at a time via ethernet.
Will you be using any LAN switches in between the RBR and RBR? If so, what brand and model?
WillyQ711
No, the satellites will be direct since the RBR has 3 ethernet ports. However, There will be a Netgear 8-Port Gigabit switch 300 series connected to the RBR as well for the other devices in the home (TV's, Printers, etc.). 3 of the ethernet ports on the RBR will go to the satellites, and the 4th to the switch.
- CrimpOnFeb 24, 2021Guru - Experienced User
WillyQ711 wrote:No, the satellites will be direct since the RBR has 3 ethernet ports. However, There will be a Netgear 8-Port Gigabit switch 300 series connected to the RBR as well for the other devices in the home (TV's, Printers, etc.). 3 of the ethernet ports on the RBR will go to the satellites, and the 4th to the switch.
Which Orbi router is this again? I count (1) WAN port and (3) LAN ports on my RBR50.
- WillyQ711Feb 24, 2021Aspirant
SOrry, my bad.... I happen to have an RBR40 as well at my office, but forgot that this one is a CBR40, or the Cable Modem version of that router. Hence the 4 ethernet ports (WAN signal comes in through the Coaxial port).
- FURRYe38Feb 24, 2021Guru - Experienced User
Same thing for the CBK40 system.
