WillyQ711
Feb 24, 2021Aspirant
How do the Orbi devices recognize an Ethernet Backhaul setup?
Greetings, So I wanted to know how the Orbi devices, specifically my current setup with the RBS40 router and RBR20 Satellite, sense that I want or have an ethernet setup as a mesh ethernet backhaul ...
WillyQ711
No, the satellites will be direct since the RBR has 3 ethernet ports. However, There will be a Netgear 8-Port Gigabit switch 300 series connected to the RBR as well for the other devices in the home (TV's, Printers, etc.). 3 of the ethernet ports on the RBR will go to the satellites, and the 4th to the switch.
CrimpOn
Feb 24, 2021Guru - Experienced User
WillyQ711 wrote:No, the satellites will be direct since the RBR has 3 ethernet ports. However, There will be a Netgear 8-Port Gigabit switch 300 series connected to the RBR as well for the other devices in the home (TV's, Printers, etc.). 3 of the ethernet ports on the RBR will go to the satellites, and the 4th to the switch.
Which Orbi router is this again? I count (1) WAN port and (3) LAN ports on my RBR50.
- WillyQ711Feb 24, 2021Aspirant
SOrry, my bad.... I happen to have an RBR40 as well at my office, but forgot that this one is a CBR40, or the Cable Modem version of that router. Hence the 4 ethernet ports (WAN signal comes in through the Coaxial port).
- FURRYe38Feb 24, 2021Guru - Experienced User
Same thing for the CBK40 system.
