kuact78
Oct 18, 2019Aspirant
How do we connect 2.4Ghz wireless devices on the Orbi network?
I have problems getting my Yale door viewer and roomba to connect to my home's wireless network. The devices say they cannot detect the network. Can someone please help?
Oct 19, 2019Guru - Experienced User
As mentioned by CrimpOn, just temporarily disable the 5G SSID Broadcast, then setup your 2.4Ghz only devices. After they are setup, re-enable the 5G SSID broadcast then you'll be ready to go.
