kuact78
Oct 18, 2019Aspirant
How do we connect 2.4Ghz wireless devices on the Orbi network?
I have problems getting my Yale door viewer and roomba to connect to my home's wireless network. The devices say they cannot detect the network. Can someone please help?
CrimpOn
Oct 19, 2019Guru - Experienced User
Another suggestion that appears to work in some cases is to temporarily tell the Orbi to stop "broadcasting SSID" on the 5G network. This is easy on the web interface on the Advanced Tab->Advanced Settings->Advanced Wireless Settings. Tell the phone you are using to "forget" the Orbi WiFi network, then connect to it again by selecting from the list of WiFi nodes and entering the WiFi password. After the setup is complete, the Yale or Roomba should be connected and you can go back and tell the Orbi to begin broadcasting the SSID on the 5G network.
michaelkenward
Oct 20, 2019Guru - Experienced User
For those of a visual turn of mind:
- kuact78Oct 26, 2019Aspirant
Thank you to all who have been very kind and generous to reply to me. I have tried the methods that you all have kindly advised. However, it still does not work. I have attached a screenshot of my wireless settings for your guidance. Please advise and help me.
