kreid4's avatar
kreid4
How do you close open ports?
I have been running port scans using nmaps and other software.  It that shows there are 9 open ports.
If I use an online check to see if these ports are open they are reported as closed.
Should I be concerned about this?
 Also my ISP has warned me about an open port 53 (DNS resover)   and possible DoS.
Thank you
K
Netgear orbi
  • CrimpOn's avatar
    CrimpOn
    Open ports facing the internet (WAN side) are a concern.
    Open ports on the LAN side are required for the router to function.  Port 53 is DNS.  Port 80 is http.  Port 8443 is https. etc.
    If you list the ports, perhaps people will notice one that is unusual.
    When I do a port scan from one of the public scan sites, I believe it shows no ports: https://www.grc.com/x/ne.dll?bh0bkyd2
    • kreid4's avatar
      kreid4
      PORT      STATE    SERVICE
      21/tcp    filtered ftp
      53/tcp    open     domain
      80/tcp    open     http
      443/tcp   open     https
      631/tcp   open     ipp
      3333/tcp  open     dec-notes
      5555/tcp  open     freeciv
      20005/tcp open     btx
      49152/tcp open     unkn
      I get this report if i run nmaps locally using my local ip number for my router (192.168.x.x)
      All ports shown as 'stealth, when using shileds up.
      Thank you
      K
      • CrimpOn's avatar
        CrimpOn
        If 53 is not open, no device will be able to access the internet in any practical way.  Port 80 is used to administer the Orbi.
        Since these are all on the LAN side, I do not see these as an issue (although I will continue to look at them).
        MUCH more interested in what Gibson says about from the WAN side (where the bad guys are).
