LBaez
Feb 11, 2020Aspirant
How do you increase Orbi RBK53 satellite speeds? Receiving poor speeds in one of my satellites...
Current Set up recently upgraded to +400 mps cable speed internet. RBK53 (only using 2 towers at this time, 3rd tower totally off line not in use) Live in a 1,650 sqft condo Main router is in on...
- Feb 12, 2020
What is the Mfr and model# of the ethernet switch in the configuration?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
LBaez wrote:Current Set up
Main router is in one corner of 1st floor level. 2nd unit in office second level opposite side. Units are connected via ethernet network CAT5e wiring that was place by previous owner of the condo.
Ive enabled all the options like beam force and all that as well.
My Network ethernet seems to work fine when i had 100mps internet. Once I upgraded to 400mps I came to notice that my satellite speeds where (to me) still poor only reaching areas of 100mps even less at time.
My main rounter speeds are +400mps but when i test from onear my satellite I'm lucky ill get 100mps
I tested speeds from the satellite with the network wire and they are poor 90-100mps
I tested speeds without the network ethernet in place I get 100-125mps
The question will be how do i get my satellite speeds up to par near to 400mps. Should i run the network wireless and add my 3rd tower?
Replace the Network cable and might as well make it a CAT6?
Truely just want faster speeds through out the house and especially in my office, how can I achieve higher speeds?
TIA!
Feb 12, 2020Guru - Experienced User
Yes take the check mark out of the check box and this sets 40Mhz only.
LBaez wrote:modem is an arris sb6190 its suppose to be able to handle speeds of +400mb
not sure where is the 20/40 MHz Coexistence. cant find the only 40mhz only option as the only one is the enable option for 20/40 MHz Coexistence- im going to try and disable it and see how that goes and i did try messing with those options ill try a bit more thanks!
LBaez
Feb 12, 2020Aspirant
Thanks did a factory reset, set up all 3 towers now, and adjusted a bit on my settings left the 20/40 coexistance off. I do believe that may have done the trick on my satelitte speeds
with out my network LAN connected to the office satelitte speeds are just under 300mps
WITH the LAN connected just over +300mps im happy with this and thanks for your help/input
- FURRYe38Feb 13, 2020Guru - Experienced User
Good to hear. Please mark your thread and solved so other will know.
Enjoy. :smileywink:
- LBaezFeb 13, 2020Aspirant
Do you recommend beamforce, mu-mimo, and fastroaming to be enabled as well?
which is recommended to be on?
- CrimpOnFeb 13, 2020Guru - Experienced User
I turned them all ON. Seems like "a clue" to me that the new "AX" Orbi's come with these feature "on" and no way to turn them off.
