josephg304
Aug 01, 2020Tutor
How do you set up an access point for the Orbi RBK50v2, so that I can access the Orbi from my PC
I cannot access my Orbi RBK50v2 through my computer, using (1) orbilogin.com, (2) orbilogin.net, or (3) the ip address of the Orbi router (192.168.0.5, assigned by my modem). I've tried multiple bro...
- Aug 02, 2020
Thank you all for your quick responses. Very much appreciated.
I was able to configure my Orbi to an Access Point, and now I can login to the Orbi from my computer.
My ISP provider is TDS Telecom, and it is a fiber connection. My modem from TDS is an Actiontec, and I have its wi-fi capability disabled. My home network has direct Ethernet cable runs from the ActionTec modem to my TV box, my media computer, and my main network switch. My Orbi is connected to the network through one of the network switches.
For whatever reason, TDS assigned the gateway IP address on the ActionTec modem as 192.168.0.1, and all of my connected devices have IP addresses in the order of 192.168.0.x. My Orbi has been assigned an IP address of 192.168.0.3.
The Orbi's main unit and satellite give me excellent wifi coverage and strength across my entire 2.3 acres property. I believe that I made the right choice in purchasing the Orbi, and this vibrant support community makes my choice even better.
Thanks again.
Mstrbig
Aug 01, 2020Master
josephg304 wrote:I cannot access my Orbi RBK50v2 through my computer, using (1) orbilogin.com, (2) orbilogin.net, or (3) the ip address of the Orbi router (192.168.0.5, assigned by my modem). I've tried multiple browsers, and I've cleared the cache on each of the browsers. When I attempt to ping the Orbi from my computer through a command prompt, I get request timed out.
I downloaded the Orbi app to my Pixel 4XL phone, and I can log in and see information on my Orbi.
The Orbi seems to be working, as my devices using wifi can connect to the Orbi and connect to the Internet through the Orbi.
I read in another discussion on this Forum that I need to configure the Orbi as an Access Point, in order to access the Orbi through my computer. Using the phone app, I do not see anywhere where I can configure the Orbi as an access point.
Please give me some guidance on how I should proceed from here.
Thanks in advance.
What modem assigned 192.168.0.5? Was it your ISP modem? What brand and model is your ISP modem?
It's been my experience that ISP modems generally assign 192.168.1.1.
I'm assuming that orbilogin.com and orbilogin.net are defaulted in the code to reflect 19.168.1.1.
And you say you can't access the Orbi by going to 192.168.0.5? That would tell me that 192.168.0.5 is not your Orbi IP address.
Look in the app and see what IP address it is showing.
You should not need to configure the Orbi as an access point, to access it thought your PC.
