fmalloy
Nov 04, 2020Luminary
How does Pause/Resume work?
I want to start disconnecting WiFi devices from the network one-by-one to try to debug a WiFi slowdown issue I'm having. I don't know how Pause/Resume works on the Orbi app, and if that's an easy/leg...
Nov 04, 2020Guru - Experienced User
It's supposed to stop traffic in and out to the device.
I would recommend turning OFF the device or turn OFF the devices wifi radios instead if your troubleshooting issues. There could be other things happening if the wifi radios are still enabled and connected...
