Drj37
Sep 23, 2016Aspirant
How does the orbi compare to the AC5300 Nighthawk X8 Tri-Band WiFi Router
Is the orbi better or should I keep the x8 I know one thing before I could get a signal all the way out in the yard with the AC1900 Nighthawk Smart WiFi Router but with the x8 I can't so I'm just wo...
spewak
Sep 25, 2016Luminary
That is the Router that I replaced with the Orbi. Once installed, the Router and the Satellite will give you faster wifi speeds at distance than the X8. I had an extender in the same spot I place the Orbi satellite and my download speeds are 5 to 7 Mbps faster.
