Drj37
Sep 23, 2016Aspirant
How does the orbi compare to the AC5300 Nighthawk X8 Tri-Band WiFi Router
Is the orbi better or should I keep the x8 I know one thing before I could get a signal all the way out in the yard with the AC1900 Nighthawk Smart WiFi Router but with the x8 I can't so I'm just wo...
DarrenM
Sep 26, 2016Sr. NETGEAR Moderator
Hello dpdurst
The guest network is planned for a upcoming firmware but in the mean time you could use your old router as a ap for a guest network as a workaround I know that it is not ideal but just giving the suggestion.
DarrenM
dpdurst
Sep 26, 2016Luminary
I get that about using the old router, I'd like to say that's a cop out excuse, but it is not. Folks buy a router to have only one in use not to take up a whole shelf of them for different features. I hope that the future means in the next few months and not a year from now.
Short of the guest access I really do like the setup of Orbi and the constant stable connection around the house and backyard. In this respect so far I give a 5 star rating to the router.
