Drj37
Sep 23, 2016Aspirant
How does the orbi compare to the AC5300 Nighthawk X8 Tri-Band WiFi Router
Is the orbi better or should I keep the x8 I know one thing before I could get a signal all the way out in the yard with the AC1900 Nighthawk Smart WiFi Router but with the x8 I can't so I'm just wo...
peteytesting
Sep 26, 2016Hero
hi Drj37
if your question is on wifi coverage alone i can tell you that in combination the orbi and its sat do indeed provide better "coverage" that even the best 2156M wave 2 type routers and that is orbi claim to fame
you cant however compare the orbi routing features or flexability as its designed primarily to be a set and forget / plug and play type system , the primary user base for this wont care about other features
those expecting the orbi to be an x8 with a sat will be disapointed but again thats not who the orbi is aimed at and not what its designed to be
i have read many of the posts here and have heard it should have this or should have that , well it doesnt and prob wont and ppl are barking up the wrong tree to expect it
the orbi for what it does is great and thats as a whole home wifi solution
dpdurst
Sep 26, 2016Luminary
My first comparison against the RT5300 outside back yard connected via the Sat and got a full 30 meg download and a 585 meg connection rate. Never could get close to that with the 5300, big win right there!
