Drj37
Sep 23, 2016Aspirant
How does the orbi compare to the AC5300 Nighthawk X8 Tri-Band WiFi Router
Is the orbi better or should I keep the x8 I know one thing before I could get a signal all the way out in the yard with the AC1900 Nighthawk Smart WiFi Router but with the x8 I can't so I'm just wo...
TheEther
Sep 27, 2016Guru
Wi-Fi transmission power is regulated by the government and walls will play havoc on signals, so there is only so much a single router can do versus a distributed system like the Orbi. The Orbi is purpose-built for expansive coverage. The Orbi has a key feature of using a separate, dedicated wireless connection between the base and satellite, so there isn't the usual 50% speed penalty typically experienced with a router + wireless extender setup. Against a router + wired Access Point, however, the Orbi may not perform as well; the dedicated wireless connection between the base and satellite still can't beat the performance and reliability of a Gigabit Ethernet connection. IOW, if your house is wired with Ethernet, the Orbi may not provide any significant advantage.
Judging from the manual, the Orbi doesn't seem to be lacking too many features. It appears to have basic features (QoS, port forwarding, site blocking). Guest networking is the only major omission. If Netgear is able to add this with full isolation, even through the satellite, then this will be a major advantage over a router + extender setup. Getting it to work will require Netgear to internally use VLANs, so that's probably the reason for the delay.
peteytesting
Jan 22, 2017Hero
yes the orbi does have the basic featureset ( now including guest wifi ) but it certainly doesnt matchup with the likes of the r8500 or asus rt-ac88u for featureset or flexability and thats what im trying to get at , if your coming from a big honking router like the ones above you may well be a little underwhelmed at the gui featuresset and capability
the orbi is designed for whole home wifi and thats what it does in spades but if you need full blown access controls and firewall cabilities and or features you would see in a big honking router you may revert to running the orbi system in AP mode and a different router doing the heavy lifting
i dont have an issue with the orbi not being so up to spec router wise apart from its expense which you would think it should have all the bells and whistles it could for the price
pete
