tmmgeekette
Jan 10, 2019Follower
How I fixed our intermittent internet connectivity problems with the Orbi
Hello, I'm just putting this here in the hopes that it might help someone down the road. I don't think this would fix everybody's woes with the Orbi, but at the risk of jinxing myself, it's what ha...
Jan 14, 2019Guru - Experienced User
Be aware of what others are seeing with the Pace Modem:
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-message
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
30 feet is recommended in between the Orbi base and satellite(s) to begin with depending upon building materials.
Enjoy.
