tmmgeekette
Jan 10, 2019Follower
How I fixed our intermittent internet connectivity problems with the Orbi
Hello, I'm just putting this here in the hopes that it might help someone down the road. I don't think this would fix everybody's woes with the Orbi, but at the risk of jinxing myself, it's what ha...
ekhalil
Jan 14, 2019Master
tmmgeekette wrote:
....... I turned off dmzmode for the orbi connection(port) and turned on firewalling for that port on the Pace router. Every firewalling option available is selected. I didn't think not having IP passthrough to the orbi would work, but it does.
Great troubleshooting! Thanks for sharing this information.
One note, when you turned off the dmzmode in the Pace router you ended up with two routers in your network: the Pace router (which is nor a full router when you removed the dmzforwarding) and Orbi. In certain conditions the Pace router will start supplying your devices with IP addresses and this will cause you troubles. You also have now double NAT.
You don't need to change anything now since everything is working fine for you, but be aware of this if you see any access issues in the future.
Good luck!
