Slun80
Apr 30, 2018Star
How is this product so bad?
How is it possible? I was so excited to use this solution. Went to Costco with a smile on my face. Felt good about buying it and carrying it out of the store. Told a bunch of friends and family a...
Slun80
Apr 30, 2018Star
Lucky!
budy
Apr 30, 2018Luminary
No, no luck involved, as far as I can tell. I have installed three different Orbi setups, one RBK53 and two RBK40 and none of them shows any of the issues, which are widely discussed on this forum. All of them are in very different environments, one with wired backhaul and two with wireless backhaul. Admittedly, all of the Orbis are running in AP mode, since all networks are DSL-based and connect via their resp DSL routers - all of them being FritzBoxes, to the internet. My RBR40 has only rebootet, when I had it installing a new fw.
