BDTECHIES
Aug 17, 2017Aspirant
How many clients?
In my experience with the Orbi routers: after 4 months of use the routers can't connect to the Internet anymore. I'm not using the Orbi's DHCP but my server's. In the DHCP I have made a specific rest...
DarrenM
Aug 21, 2017Sr. NETGEAR Moderator
Hello BDTechies
There shouldn't be since you are using it in AP mode and using your own router to handle the DHCP.
DarrenM
BDTECHIES
Aug 21, 2017Aspirant
Thanks... What I've done is simply a Factory reset and set everything back from scratch. And it works now. I'm still unsure of what caused this and I'm a bit a worried to say the least...
