JCORBI
May 14, 2020Tutor
How many feet can a Back Hauled Satellite be located from Router?
I have "poor" connection indicated in Admin and in the app it has a yellow dot. My garage is about 50 feet from the house but by the time it goes through the house and garage Ethernet cable from rout...
- May 14, 2020
Wireless backhaul yes, 30 to upwards of 60 some have posted having there RBS connected to the RBR.
Wire ethernet connected only depends on the length of the cable so if you have 100Ft between the RBR and the remote location, the RBS will work ethernet connected.
Its recommended to first connect the RBS to the RBR while in the same room. Wirelessly, then wired temporarily. You might do a IP address reservation on the RBR for the RBS so you can keep track of there IP addresses. Once this is done. Turn OFF the RBS and place and connect the RBS in the remote location with the ethernet cable there which the other end should be connected to the back of the RBR.
May 14, 2020Guru - Experienced User
