jimbobbob's avatar
Apr 17, 2018
How many Orbi's can I return? I bet a whole bunch.
Trying to add an RBS50 to a RBK50 system.  Instructions say turn it on, wait until light is solid white.  Today's device arrived, took 10 minutes to stop flashing, then turned red.  Before I even moved to step 1 or trying to start a sync.  Reset the device, same behavior.  Pissed me off.  Back in the box it went.  I suspect the instructions are wrong.  But if they are, I'm going to return quite a few before I look for further advice.
Anybody know off hand if these instructions are wrong?
  • FURRYe38's avatar
    Whats the Mfr and model# of the ISP modem your connecting the Orbi router to?
    Did you attempt to log into the routers IP address at 192.168.1.1 with a web browser with LAN cable PC connected to the orbi router and walk thru the setup wizard?
  • Retired_Member's avatar
    Retired_Member
    Red...?  As in maybe too far from router..??  I'd move it closer to the router (if possible) and try again.
    • jimbobbob's avatar
      jimbobbob
      Tutor
      I already have a functioning RBK50 setup - router and satellite.  I'm impressed with that system, although I recall the satellite on that system did not go according to instructions either (although I might be remembering incorrectly).  That system's working great.  New satellite is going in only 20 feet from the prior one (I want access to the Ethernet ports in this location).
      But why did this satellite boot straight up into disconnected mode, when included instructions say it will come up with solid white light?
      • FURRYe38's avatar
        May have been in a bad configuration out of the box.
        Does the Satellite work now?
