sillyusername
Nov 19, 2018Follower
How many satelites does a RBK50 — Orbi AC3000 Tri-band WiFi System support?
I am considering the Orbi RBK50 for my home. It is a large home spread out over a single storey, with a lot of brick and glass.
The fibre has been terminated by the ISP in the worst place possible for this home, but i cannot change that as I am renting.
So, i need wifi to extend about 50m from where the router will be connected in 3 different directions, through glass ranch slider doors and windows.
I see the RBK50 pack is 1 router and 1 satelite. Can i add additional satelites? If so, how many?
I currently have a Google WiFi kit but it complains when you try hook up additional satelites b/c they are too far from the main router (implying that it's not a true mesh, else it could just piggyback off the other mesh points?).
- aani75Apprentice
I added 6 satellites and working fine for me. I have 5000 sq ft on 3 stories covered by 2 satellite on each floor and RBK50 in the center of the Basement.
I have a 5000sq ft hone, two story. Have the Orib base at one end and just one satellite at the other end at about 40 feet in between. Great coverage and performances.
30 feet is recommended in between base and satellite(s) to begin with depending upon building materials.
Add what you see fit or what the system seems to lack in if you have a wide area to cover.
Daisy Chain is NG piggy back feature for satellites.
- DickDukeApprentice
The RBK53 should do it. RBR50 router plus 2 satellites. Latest firmware supports daisy chaining, so you should have no problem covering up to about 100 linear feet. Maybe as much as 10000 square feet.
- SMM_COAspirant
I have a 3 unit setup of RBK50 (Router, 2 satelites). Need to add two more.
Why is the Orbi system limited to 3 satelites?
NG seems to think that a router plus two is good for most general large house holds. In most cases is it.
The router alone can cover up to 1500 sq ft.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Other posters have mentioned adding 3 more satellites on to there existing systems...
- SMM_COAspirantThe size of the house is 8,200 sq ft. I have a couple of smart devices that are beyond the sq ftg of the house on the other side of a large garage. Plus Verizon and AT&T have terrible coverage at the address so WiFi enabled calls drop in the garage.
