Rsierra
Oct 19, 2021Aspirant
How many satellites can an Orbi RBR50 support?
Hi, can you share how many satellites can I have connected to my Orbi RBR50? I currently have 3 and would like to add another satellite. Also would I be purchasing an RBS50 to add to the network...
Oct 19, 2021Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- RsierraOct 19, 2021Aspirant
Thank you! I noticed that Netgear sells a satelitte for $250 but I see many on Ebay. Any disadvantages to purchasing a used satellite?
Ralph
- CrimpOnOct 19, 2021Guru - Experienced User
Like anything on eBay, the issue of defective products and/or returns is more compicated than with a major retailer with a well-established return policy. Used products cost less, but come with no warranty from Netgear. That being said, after my Orbi was out of warranty I got a second RBR50 router for under $100 to use for experiments and as a spare. Works great.
- FURRYe38Oct 19, 2021Guru - Experienced User
You can also use RBS20, RBW30, RBS40v as alternative units.
