aussie188
Jul 24, 2018Follower
How many satellites?
Hi,
Im considering purchasing the RBK50 but I'm not sure if I will need another satelite to get decent signal.
I live in a one storey 400 square metre home made of brick. I need the signal to rea...
- Jul 24, 2018
Recommended starting distance between the Orbi router and satellites is about 30 feet to begin with, also depends on building materials. So with brick you may need to be a tad bit closer...maybe 25 feet. Placement of sateliites will be key.
I live in a 5000 sq ft home and use 1 base and 1 satellite, 40 feet in between. However my home is wood and sheet rock.
Jul 24, 2018Guru - Experienced User
