thuynhj
Jan 25, 2023Aspirant
How often do you reset your wifi password?
From a security perspective how often do you reset your wifi passwords? What is your process?
Every 20 years, without fail..... (maybe. I'll know in 2025)
It is over 20 characters long. If someone guesses it, they are welcome to use my internet connection.
I'm the same. I set a password about a decade ago and haven't changed it. But I also watch my attached device list. If someone happens to pop on it, i'll change it. But otherwise it makes upgrading routers super easy.
- thuynhjAspirant
When you stated "watch my attached device list" are you referring to the Orbi app or are you using a different software for that?
- KevinLiTNETGEAR Moderator
Hello thunynhj,
Welcome to the NETGEAR Community!
plemans is referring to the "Device manager' that can be found within the Orbi app.
To see this information tap Device manager when you open your Orbi app.
For more information about the device manager please navigate to the link below:
How do I view the devices connected to my Orbi WiFi System? | Answer | NETGEAR Support
Best,
Kevin
Community Team
