DL19545698
Aug 05, 2020Aspirant
How to block ghost calls
The VoIP device has been receiving ghost calls from a fixed IP (seems to be self-generated from the router). There is a suggestion to forward the Port 5060 to an internal IP address outside the DHCP...
DL19545698
The VoIP device is Polycom RealPresence Group 500.
The ghost calls (only receiving ringing tones but no callers at the other end) have been generated from a fixed IP address with the following displays, like :
[email protected]; etc.
The IP address is the Polycom device internal IP.
Aug 08, 2020Guru - Experienced User
I would contact the phone Mfr to see if they have any information on this. They may have features to help on this.
DL19545698 wrote:The VoIP device is Polycom RealPresence Group 500.
- DL19545698Aug 13, 2020Aspirant
Polycom support said the H.323 protocol has no function in stopping ghost calls. They recommend a blocking at the router end. That's a suggestion of forwarding the port and open the WAN and I just wonder would such suggestion would work and would like to know if anyone has tried this before.
FURRYe38 wrote:I would contact the phone Mfr to see if they have any information on this. They may have features to help on this.
- FURRYe38Aug 13, 2020Guru - Experienced User
You could try using PF and input in a IP address that is not used by the RBR or a device and see if this would help though not sure if the call would still be fully blocked or not. Try using 192.168.1.253 as a PF address to use. Make sure your devices are not assigned to this address.
